how to create meshes of conformal nodes?
1 Attachment(s)
i use following methods to create meshes of conformal nodes, but fail.
1.create volume meshes in one region,then translate it into unstruct meshes 2. select respect line elements in "global mesh parameters "box 3 . create surface meshes according to this existing nodes on the common lines. and make sure the nodes color on the common lines is green. but it actually fail. who can tell me how to solve this problem? especially dear PSYMN. I look forward to your reply. thanks a lot. |
Hi, snailstb.
Did you associate the edge of block with the common lines? If don't do so, no line elements generated on the common lines, therefore, line elements won't be regarded in the process of tetra creation. |
