combustion chamber meshing
Old   March 14, 2010, 06:53
Default combustion chamber meshing
renu is on a distinguished road
Good evening friends,
Iam trying to do cold flow analysis of a Diesel engine. For that i want to mesh the combustion chamber(inlet,outlet,piston,cylinder).From tutorials i got some idea about dynamic mesh.
1)But iam confused about how to start the initial mesh with ICEM.
2)Means which one i have to mesh first.and which type of mesh i have to use,Tetra or Hexa.(For which we component we have to use surface and volume meshes)
Here iam expecting small suggestions thats enough.
Thanks in advance.
renu is offline   Reply With Quote
Old   March 15, 2010, 09:04
Default Small answer
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If you are planning for birth and death of cells as the piston moves, then you should at least do the cylinder with hexas... Similarly, you may want to model a cylinder around the valves and put hexas in there.
You really could do the entire bowl with hexa, but some people find that difficult to do.
You could also use Tetras to more easily mesh any "difficult regions".
You would then need to merge your tetra and hexa regions together...
It is really a big question with lots of variables, and this is really a small answer...
PSYMN is offline   Reply With Quote
Old   March 15, 2010, 22:31
Good morning friends.
Thanku for u r replay.
can we mesh entire combustion chamber with tetra mesh.
Old   March 16, 2010, 14:05
Default Sure...
PSYMN's Avatar
Simon Pereira
I have seen it done that way... Not often, but I have seen it.
ICEM CFD-- ic engine combustion chamber meshing chetan mundhe CFX 15 July 22, 2012 18:34
combustion chamber meshing renu Main CFD Forum 0 March 14, 2010 06:49
[GAMBIT] Dynamic Meshing of a combustion chamber donarundas ANSYS Meshing & Geometry 1 December 2, 2009 07:13
Coal particles in combustion chamber Luis Filipe Fabiani CFX 2 March 10, 2009 15:37
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
