-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] How to eliminate overlapping elements? (http://www.cfd-online.com/Forums/ansys-meshing/73827-how-eliminate-overlapping-elements.html)
ringtail March 18, 2010 01:29
2 Attachment(s)
Hi, everyone
I have generated an O grid mesh, which is showed in the following picture.
When I checked the mesh quality, I found there were some overlapping elements. Who can help me eliminate the overlapping elements?
thanks.
Attachment 2624
Attachment 2625
PSYMN April 21, 2010 18:44
Should not do that...
That looks pretty ugly... Hexa should not do that.
Can I see the files?
Simon
ringtail April 21, 2010 23:51
Simon
Hi, Simon.
That is my first try to mesh a 2d cylinder. And now i know why it looks so ugly: i have used "smooth mesh globally" function.
Simon, can you help me about my current trouble :how to refine the mesh?
I have described the problem:
http://www.cfd-online.com/Forums/ans...mputation.html
Generally speaking , i mean that i want to coarsen the mesh but the mesh should satisfy the following demand:
1. the first layer mesh should be close enough to the wall to make sure y plus approximate to one.
2. aspect ratio of mesh should not be big in order to be true of FLUENT's limitation.
thanks very much.
zdeth September 24, 2010 16:30
did you find a fix to these overlapping nodes? I'm having a similar problem where it just kinda goes up and folds over on its self..
ringtail September 25, 2010 09:19
I had smoothed the mesh using ' global smooth'. This was the reason why there were so many overlapping nodes...
PSYMN October 5, 2010 19:22
All set?
Hey Ringtail are you all set on this... I can't tell much from your image. I don't even know if you have an Ogrid. I would need better images or the actual files to help any more on this one.
Best regards,
Simon
