[GAMBIT] mesh problem
Old   March 30, 2010, 09:04
Default mesh problem
bob12 is on a distinguished road
Hi everyone,
i have a problem with mine mesh. The geometry is a cube where inside there are a circular hole. In the summit of a cube i have a split so when i'm going to meshing the volume with a cooper schem i have an error for this split.
is there a method for meshing the volume without doing a split in lower surface of cube?
thanks for any suggeston
bob12 is offline   Reply With Quote
Old   March 30, 2010, 12:50
Chris
Chris D is on a distinguished road
Originally Posted by bob12 View Post
Hi everyone,
I would split it like this:
All faces are meshed with a structured mesh. For some of the faces (see the picture,) you need to change one vertex from "end" to "side", because the quad:map scheme requires the number of end verticies on a face to be equal to four.
Chris D is offline   Reply With Quote
Old   March 31, 2010, 02:55
the problem is showing in the second picture. i have a similar geometry, but the volume that not have the mesh in picture in my case there aren't a split so is a simple cube.
for resolve the problem i do the split this cube or there is a method for meshing without it.
Old   March 31, 2010, 08:08
Chris
Hmm, I'm not sure if I understand. In you case, does the circular hole go completely through the cube? Maybe if you posted a picture the problem would be more clear.
Old   March 31, 2010, 10:45
thank you chris i have resolved the problem !!
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
[GAMBIT] Problem with mesh. Please Help... maziboss ANSYS Meshing & Geometry 1 September 28, 2009 02:24
mesh generation problem Ellen FLUENT 7 February 18, 2009 21:20
mesh control problem TUM CFX 4 July 27, 2001 16:17
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 20:26
