O-grid generation unsuccessful
Old   March 30, 2010, 18:35
Default O-grid generation unsuccessful
Jialin Su
sujialin is on a distinguished road
I created a single block to fit a 3D wing and tried generate O-grid around the block. But it ended up with a warning saying that generation of O-grid is not successful and I could not proceed with the mesh generation. Has anyone encountered something similar and could anyone provide advice on that? Thanks.
sujialin is offline   Reply With Quote
Old   March 31, 2010, 01:35
Anorky is on a distinguished road
How did you try to create the o-grid?
Have you tried the tutorial on the wing body?
regards
Anorky is offline   Reply With Quote
Old   March 31, 2010, 09:57
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Right, Ogrid is very robust, but you need to pick it correctly... Try the tutorial first and then get back to your wing...
PSYMN is offline   Reply With Quote
Old   April 5, 2010, 11:37
Jiang
panda60 is on a distinguished road
Dear all,
I always can't be succeful with O grid.
in ICEM have no problem, but when imported into fluent, always diverge, so I doult my O grid have problem. This is the first time I use O grid, who can give me some suggestions ?
My model is not complicated, one building in an rectangular domain, I want to generate an O grid around the building.
my method is seclecting the block and a face, and then associate the internal O block vertics with the building geometry.
Who can give me some suggestions, what I should pay attation to when using O gird , if I should associate edges or orther face with geometry ?
Thank you very much.
panda60 is offline   Reply With Quote
Old   April 6, 2010, 03:15
jsm
JSM
jsm is on a distinguished road
From your screen shots, I think that mesh is good. Could you check the mesh quality and errors in ICEM CFD? If fluent reads your mesh and passed the grid check, then mesh has no errors. I think that some solver set up may be causing the divergence. So recheck once again the sover set up.
Hope this will help U
With regards,
JSM
jsm is offline   Reply With Quote
Old   April 6, 2010, 03:22
jsm
JSM
One more thing. Are doing mesh for building also? Did you define the two domains (one for building and another one for outer area) in ICEM CFD. In fluent, just check there are two domains or not.
If you defined correctly or you are not modeling the building (you already deleted the block inside building in ICEM CFD), just ignore this reply.
With regards,
JSM
Old   April 7, 2010, 10:25
Jiang
Dear JSM,
Thank you very much.You are right, the grid have no problem. Because OpenFOAM can simulation. So I check fluent solver set again.
When I decrease the under-relaxation factors, doesn't use the defalt value, the simulation can going on. But when you use regular tectangular mesh, using default set is OK.
This is mesh quanlity.
need help for generation grid aya FLUENT 11 March 4, 2008 14:46
Help Re. Grid Generation Patel Amit R. FLUENT 1 February 28, 2003 21:27
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Latest new in mesh generation Robert Schneiders Main CFD Forum 0 February 16, 2000 07:12
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
