How to divide a surface?
Old   June 10, 2010, 05:53
Unhappy How to divide a surface?
chiara
chisa is on a distinguished road
Hello to everyone!
Does anybody of you know how to split/divide a surface?
To better say: I have a body with a hole inside; the surface of the body that is in contact with the hole, i want to divide it in two part...because then...when I will set the boundaries condition, i want to give to these two different part of the same surface, 2 different setting.
Is it possible?
thank you very much...I really need your help!!!!
chisa is offline   Reply With Quote
Old   June 10, 2010, 08:22
Matthias Voß
mvoss is on a distinguished road
hey,
which mesher?
For WB mesher --> draw the circle whereever you want to have it and extrude it by imprinting surfaces; you have to unfreeze the "imprintable" body before.
For ICEM --> draw the circel.... and then just cut the face by curve and add a new part for the "circlesurface"
neewbie
mvoss is offline   Reply With Quote
Old   June 11, 2010, 05:44
chiara
Thank you very much for your help!
divide surface
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
