[ICEM] Question about boundary type recognition when import mesh from IcemCFD to Fluent |
April 22, 2010, 04:50 |
Hi all,
First of all, thank you for viewing my post.I am trying to make a pipe with velocity-inlet (in the center)and pressure-inlet(around previous one with cirque shape) at one side of the pipe, the other side is pressure-outlet by using ICEM. when i use tetra meshing, it was perfect read by Fluent with boundary condition. however, when i try to use hex meshing, there always omit the center part which defined in ICEM, only read these two parts as a entity(a round surface boundary),the name is recognized as either velocity-inlet or pressure-inlet. i need to use VOF model in Fluent. hope you can help me which i really appreciate Have a nice day! i think i have solved this now,thank you all but how about a quarter or semi-cylinder assosication? Last edited by dean; April 24, 2010 at 16:22. Reason: probblem solved,thank you all :) |
April 23, 2010, 10:13 |
How did you solve it?
Simon Pereira
Rep Power: 47 |
I assume the problem had something to do with associations or blocking material?
Since you solved the problem yourself, how about posting what it was so others who may be having the same problem can fix it also. Simon |
April 23, 2010, 10:17 |
Hi Simon,
Thank you for replying my post.i change to O-grid to apply blocking assosiation.and, is that you put lecture on the youtube?i really like it have a nice weekend |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
[mesh manipulation] Using createPatch in place of couplePatches | sripplinger | OpenFOAM Meshing & Mesh Conversion | 8 | November 13, 2009 07:14 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
