[Gambit] surface distortion
Old   April 23, 2010, 04:16
Default [Gambit] surface distortion
Jouke de Baar
jack1980 is on a distinguished road
When I mesh a surface in Gambit, the mesh in one of the corners is distorted:
When I mesh the volume it has highly skewed elements. How can I fix this? Is there some way to smooth the surface?
Thanks!
jack1980 is offline   Reply With Quote
Old   April 26, 2010, 02:17
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
try to split the surface in the region where the distorsion occures.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
[GAMBIT] Help with 2-D surface element sizing siw ANSYS Meshing & Geometry 3 November 3, 2009 03:22
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
