Home > Forums > ANSYS Meshing & Geometry
[ICEM] uncover faces error
Old   April 27, 2010, 19:25
Default uncover faces error
Ming
h.m lee is on a distinguished road
After watching the demonstration 'Indy Car - Extreme' in ANSYS's demo room (http://www.ansys.com/demoroom/zoom.aspx?d=14), I create a simple geometry to practice this approach. This demonstration presents an approach that from surface mesh to boundary layer volume mesh then the rest volume mesh.
In lights of this approach, I created surface mesh, then prism, and tetra for the rest. After that, I checked the whole mesh, an error message, ' uncover faces' was reported.
How can I solve the matter?
And, I am using ICEM 12.1. A difference was found between my GUI (fig. 1) and the demonstration's (fig. 2).
h.m lee is offline   Reply With Quote
Old   April 27, 2010, 20:51
Default And the error meshes locate
Ming
And the error meshes locate between prisms and tetras.
Thanks
Old   April 28, 2010, 11:17
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You have a volume material with "uncovered faces".
Solvers need the shell elements on the outside of volume materials so they can apply boundary conditions.
In your case, you must have the Prism volume material and tetra volume materials in different parts. ICEM CFD expects you to have a wall of shells between these parts.
It offers you a "fix" which is just to cover the uncovered faces with sell elements. But in this case the correct fix is just to put all the prism and tetra elements into the same part. you can do this lots of ways.
1) flood fill with a material point should take care of it. This is more proper because it will handle multiple different volume regions, but it does require you to create a material point.
2) If you only have one volume region, you could right click on your volume (FLUID) part and select "Add to Part". it will prompt you to select elements. Use the last button on the tool bar to select all volume elements.
Either way, all the volume elements will be added to the correct part(s) and your problem should go away.
PSYMN is offline   Reply With Quote
Old   April 28, 2010, 11:25
Ming
Thank you, Simon. I'll try and report the progress.
Ming
Old   April 28, 2010, 11:37
Ming
I created a body, and ran flood fill. Then checked the meshes, everything OK.
Thank you.
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 23 August 6, 2014 03:50
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
Compiling Netgen on Fedora Core is driving me crazy jango Open Source Meshers: Gmsh, Netgen, CGNS, ... 3 November 9, 2007 14:29
