[ICEM] uncover faces error
Old   April 27, 2010, 19:25
Default uncover faces error
Ming
h.m lee is on a distinguished road
After watching the demonstration 'Indy Car - Extreme' in ANSYS's demo room (http://www.ansys.com/demoroom/zoom.aspx?d=14), I create a simple geometry to practice this approach. This demonstration presents an approach that from surface mesh to boundary layer volume mesh then the rest volume mesh.
In lights of this approach, I created surface mesh, then prism, and tetra for the rest. After that, I checked the whole mesh, an error message, ' uncover faces' was reported.
How can I solve the matter?
And, I am using ICEM 12.1. A difference was found between my GUI (fig. 1) and the demonstration's (fig. 2).
h.m lee is offline   Reply With Quote
Old   April 27, 2010, 20:51
Default And the error meshes locate
Ming
And the error meshes locate between prisms and tetras.
Thanks
Old   April 28, 2010, 11:17
PSYMN's Avatar
Simon Pereira
You have a volume material with "uncovered faces".
Solvers need the shell elements on the outside of volume materials so they can apply boundary conditions.
In your case, you must have the Prism volume material and tetra volume materials in different parts. ICEM CFD expects you to have a wall of shells between these parts.
It offers you a "fix" which is just to cover the uncovered faces with sell elements. But in this case the correct fix is just to put all the prism and tetra elements into the same part. you can do this lots of ways.
1) flood fill with a material point should take care of it. This is more proper because it will handle multiple different volume regions, but it does require you to create a material point.
2) If you only have one volume region, you could right click on your volume (FLUID) part and select "Add to Part". it will prompt you to select elements. Use the last button on the tool bar to select all volume elements.
Either way, all the volume elements will be added to the correct part(s) and your problem should go away.
Old   April 28, 2010, 11:25
Ming
Thank you, Simon. I'll try and report the progress.
Ming
Old   April 28, 2010, 11:37
Ming
I created a body, and ran flood fill. Then checked the meshes, everything OK.
Thank you.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Netgen] Compiling Netgen on Fedora Core is driving me crazy jango OpenFOAM Meshing & Mesh Conversion 3 November 9, 2007 13:29
