Connections of edges and faces between bodies (Workbench v12)
Old   April 26, 2010, 19:47
Default Connections of edges and faces between bodies (Workbench v12)
julien char
gexiste is on a distinguished road
Hello everyone,
I am working on the seperation flow arround a prolate spheroid.
Goal of my project: - improve the meshing with a quad method to obtain good aspect ratio and good skewness. - target the separation flow very close to the prolate spheroid.
Method: - Split the global spherical volume in some quadrilateral sector as shown in the pictures. - Inflation meshing to see the boundary layer arround the body.
Main problem : How can I do to share every edges and faces between bodies? Right now the gap between them generate a different meshing both side of the interface.
The following pictures illustrate this project and this problem.
Thanks for your help.
gexiste is offline   Reply With Quote
Old   April 28, 2010, 11:04
Default MultiBody Part
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You need to combine the parts into a multibody part so that you will get conformal mesh...
You can do this in the geometry branch of the model tree.
Simon
PSYMN is offline   Reply With Quote
Old   April 29, 2010, 16:57
julien char
Simon
thank you very much Simon , it works good like that
Julien
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
ICEM:copy-rotate -> single edges, uncovered faces? Zulu CFX 2 January 6, 2009 13:51
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
