problematic geometry
I am trying to mesh a 3D helmet in Ansys workbench, i created named selections (inlet, outlet, helmet) in meshing to import to fluent. when i mesh the fluid over the helmet, the error "problematic geometry" occurs in the named selections. The "problematic geometry" is referenced on a surface of the helmet. Can someone help with this? |
Hints...
The error says... "The following surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology."
Those small sliver surfaces are the problems... So there is the suggestion to use a smaller size. Or you could use Virtual Topology to group those sliver surfaces together into more reasonable surfaces. Or you could switch to a method that doesn't rely on Patch conforming tetra. Try the Patch Independent Tetra and see how you like it. I don't have time to run it right now, but hopefully I will get the chance and try again later this week. |
I have a similar problem with my geometry too. Did you figure out a way to mesh your part? Thanks |
