rotate a body
Old   May 5, 2010, 12:22
Default rotate a body
Eli
Electrico is on a distinguished road
I want to rotate a body 30º from the zxplane of the global coordinate system in designmodeler. Can someone help me?
thanks
Electrico is offline   Reply With Quote
Old   May 20, 2010, 15:31
Default Body Operation
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
This is probably a bit late, but it is tough to keep up with CFD-Online
You need to select the object, then go to Create (2nd menu next to File) and do a body operation. There are many types of operations, including mirror and rotate. You may first need to create an LCS if you don't already have a curve you can select for the axis of rotation...
You should be able to figure out the rest from there.
PSYMN is offline   Reply With Quote
Body in windtunnel - high preassure behind the body? Andyjoe OpenFOAM 4 February 16, 2010 10:57
Bluff body used for diffuser testing lemat1 Siemens 0 December 5, 2009 09:11
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
oscillating body fred FLUENT 1 April 1, 2005 13:41
Inside, Outside or on the boundary of a Body? AFP Main CFD Forum 2 January 25, 2004 19:43
