-   ANSYS Meshing & Geometry (
-   -   [ICEM] Couette Flow (
kasman_meng May 12, 2010 12:20
Couette Flow
Good afternoon to everybody!
I am new to this community, and also to the CFD-software world, just to realize how different the theory from the actual practice is. I am using ICEM to grid a simple geometry, and simulate the couette flow. I drew a simple 3D rectangular and inserted it in ICEM. I blocked( the block was automatically assigned to the geometry, but I also did the auto-association step, just in case. And somewhere there, I just lose it. Don't know how to proceed and obtain the mesh. The next step would be Mesh--) part mesh setup? If yes, how do I configure the fields over there? the tutorials do not explain!!
Thank you for your help!!
kasman_meng May 18, 2010 21:55
some kind guiding??? Or at least an idea of where to look for instructions!! :D
PSYMN May 19, 2010 16:05
Sorry, I have no idea what is going wrong for you... Have you tried the tutorials? They may get you going.
Perhaps some pictures would help...
kasman_meng May 19, 2010 16:43
The reason why I don't find the tutorials helpful, is because the only thing they do is tell you "what to do" without explaining the "how" and "why".. I mean that when the tutorials guide you, they just say press this, then open the other tab and do the following settings....
Anyway, bymyself, I have managed to conclude to some points, which would be the following:
i) for output in CFX you can't work in 2D
ii) First one should block
iii)Associate points and curves
iv)Mesh. If the geometry is quite simple, one should set the number of nodes on every surface. One question I have here is how do we implement the rest of settings in the tab of curve mesh parameters. As well as which is the difference between surface mesh and curve mesh.
v) If the geometry is more complicated one should refine the mesh by inserting an O-grid, closing holes etc....
This is what I've found out so far... More notices are more than welcome!!
PSYMN May 20, 2010 21:52
The Hexa training is a whole day, during which we take lots of time to explain the how and why. There are also notes about the "why" in the help.
You may want to see some of the online tutorials on the customer portal.
Or you could try the ones at (look under ICEM CFD and AI* Environment)
There is also one simple 2D one on our youtube site,
For your case, if you block it in 2D for CFX, you can extrude the blocking or the mesh, it is up to you. Optionally, you could output it as a 2D mesh from ICEM CFD in Fluent *.msh format. When you read a 2D fluent mesh into CFX, it automatically extrudes it for you.
haristrawberry September 15, 2010 08:54
hey even im trying to simulate the couette flow!! how did u simalte the moving condition in CFX pRE??
kasman_meng September 15, 2010 15:22
set the upper walll as a "wall" condition and give it a speed which is parallel to the flow direction.
haristrawberry September 20, 2010 06:12
hey got de velocity profile linear dude!!!! thanks alot
