Who can mesh this step file ?
1 Attachment(s)
Hi
Is any body here can mesh this step file ? I can not mesh this, after meshing the main face will be loss. please help me. |
Is there more?
1 Attachment(s)
You didn't really provide enough info to help you much (such as what was your problem and what kind of mesh do you even want?), but I was curious so I opened the file...
Should there be more than this? (is that what you meant by Face lost? Is something missing?) Attachment 3588 Is your problem that you have a bad model? Step is the second worst format out there (IGES is worse), if you output this from a CAD package, see if they can output ACIS (best for Gambit since it has an ACIS kernel) or Parasolid (Best for DesignModeler for similar reasons) If you output in a better format your downstream problems may go away |
