June 10, 2010, 01:11 |
Design modeler to ICEM
JSM
Rep Power: 20 |
When I tried to import the geometry from design modeler to ICEM CFD, the curves are not coming correctly. For example, I created one cylinder in DM and imported in to ICEM. The two straight curves connecting two circles are not imported. This can be created easily in ICEM. But for bigger geometries, this is extra work. I think that I am missing some thing. Any idea to solve this?
With regards, JSM |
June 10, 2010, 08:25 |
Matthias Voß
Rep Power: 20 |
hey,
if really needed, cut the cylinder in half before exporting to ICEM. neewbie |
June 10, 2010, 11:13 |
Not a translation error.
Simon Pereira
Rep Power: 47 |
I don't think that curve is in the DM model.
If you want seam curves in ICEM CFD (you don't want them for Octree and you don't need them for Hexa, but absolutely must have them for Patch Dependent surface meshing), you could try the "Geometry (tab) => Repair => Split folded surface"... Set the angle to 90 degrees. |
June 11, 2010, 00:47 |
JSM
Rep Power: 20 |
Yes. I can do this. But I think that it can be solved while importing the geometry itself.
With regards, JSM |
June 11, 2010, 01:05 |
JSM
Rep Power: 20 |
Hi Simon,
Thanks for your reply. You are correct. The curves are not created in DM. But when I import the same cylinder created in modeling softwares into ICEM CFD, I can get these curves. For further geometry modifications, these curves are really needed. If I do geometry clean up for bigger imported geometries in DM and when I import it into ICEM, once again I am creating these curves. There is any option to create these curves while importing in ICEM CFD?
With regards, JSM |
June 11, 2010, 08:28 |
Seamless
Simon Pereira
Rep Power: 47 |
Those other modelers must include that seam curve internally when they create the cylinder. The import just exposes what was already there.
The "Split folded surface" option I suggested can be applied to the entire model. You can also find cylinders in your model with the feature detection stuff (under geometry tab => repair) and you can search for surfaces with high curvature (set it to 180 degrees) and put them into a subset. I don't know of an import option to add these. Just to say it again, only try to get those cylinder seams if you are doing patch conforming shell meshing. Simon |
June 14, 2010, 22:03 |
JSM
Rep Power: 20 |
Hi Simon,
Thanks for your reply. Now I am using the procedure given by you.
With regards, JSM |
[Other] Connecting 3D bodies in Ansys Design Modeler | chipper | ANSYS Meshing & Geometry | 4 | January 25, 2018 09:45 |
Modeling Terrain in Design Modeler | Will C | ANSYS | 0 | February 26, 2010 18:13 |
Design Modeler to ICEM..... | Joe | CFX | 0 | January 24, 2008 03:39 |
CFX design modeler | Merkur | CFX | 0 | June 5, 2006 10:44 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
