April 21, 2010, 04:59 |
Check Mesh can't work !
peter wang
Rep Power: 16 |
I have been diagnosing some tetrahedral mesh with ICEM > Edit Mesh > Check Mesh. But I found some terms couldn't work, involving Delaunay-violation, Overlapping elements.
I have presented more detail about my problem in the attachments, including four mesh data file. Please give me a hand, I'm waiting online. |
April 23, 2010, 00:03 |
peter wang
Rep Power: 16 |
Why not hand? I'm waiting online!
April 23, 2010, 00:04 |
peter wang
Rep Power: 16 |
Please help me!
June 10, 2010, 02:31 |
Thanks for your kindness
#5 | |
peter wang
Rep Power: 16 |
June 10, 2010, 13:09 |
Checks for Surface mesh...
Simon Pereira
Rep Power: 47 |
Ok, I just took a quick of your attachment and see that this is just about quality metrics. I am curious about why you were doing this research...
I checked (on my own and fired off an email to development and doc) and see that the doc is correct. Your examples are not. Both of these checks are looking for surface elements (triangles), you have provided volume elements (Tetrahedrals). So Overlapping elements is not usable because it only works on surface elements (TRI_3 and QUAD_4). It checks for all surface element edges if the any angle of the vector between the centroid of the surface element and the mid point of the element edge projected into the surface element plane and the vector between the centroid of a surface neighbor element and the mid point of the element edge projected into the surface neighbor element plane is less than 5 degrees. If so this will be marked as an overlap. These can cause a problem for delaunay because it is difficult to fit a decent tetra between the overlapping tris. The Delaunay check is similar. it is meant to be run before delaunay, so it applies to tri elements only (which it says in the first few words of the doc.) Just a side note; Most Delaunay meshers are now much more robust and failing the delaunay check is no longer a concern. I usually just skip it and focus more on the critical issues of single edges and overlapping elements.... |
check mesh, delaunay-violation, overlapping elements, tetrahedral mesh |
Display Modes | |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Check error in importing mesh | HSK | FLUENT | 3 | May 26, 2008 09:19 |
how to check qlty of mesh????? | vijesh joshi | CFX | 3 | March 15, 2006 23:33 |
MESH CHECK FAILED right/left handed faces | Rodrigo Madariaga | FLUENT | 2 | June 28, 2001 10:15 |
