Face mesh and scheme
Old   June 20, 2010, 04:48
Default Face mesh and scheme
Jonny
Jonny6001 is on a distinguished road
Hello, I am looking at the SI engine tutorial by Fluent and the mesh file associated with it.
I have opened the mesh file in Gambit to look at the type of mesh required in the re-meshing zones, and I can't understand how they have meshed one region.
The image attached shows the region. Around the upper side of the valve, Fluent needs quad elements to be able to simply grow more quads for the dynamic mesh. But that face has both tri and quad elements but controlled nicely so the quad elements are only where needed, close to the head.
The face has been meshed using a Pave scheme.
If I was to simply re-mesh the face using the same scheme, I get a bad mesh that's nothing like what is currently there. There seems to be a definite line that separates the tri and quad zones but it's done as a single face, but there's no virtual geometry.
What I'm asking really is, how is this achieved and can I simply do it by splitting up the face in to tri and quad zones?
Thanks a lot.
http://img19.imageshack.us/img19/7651/meshpic.png
Jonny6001 is offline   Reply With Quote
Old   June 21, 2010, 01:29
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
As you can see, the edges aren't connected. Indeed there should not be only one edge common for quad and tri, but 2 superposed, which are disconnected.
But in Fluent, you have to work with interface, since the meshed edges aren't connected
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 21, 2010, 02:27
Jonny
Hi,thanks for the reply max.
Sorry I was unclear in my description. The face I mention is the larger one with both tri and quad. What i wanted to know is how is the face meshed with such control of element type as a single opperation, using pave scheme. You notice nice quad elements at the bottom of the face, with nothing to define the transition from tri to quad.
Thank you.
Old   June 21, 2010, 02:57
-mAx-'s Avatar
Maxime Perelli
ah ok... very interesting (I didn't see it).
I'm also curious to know how it is build.
For sure it is not a split.
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
Mesh distortion close to cylind wall-GAMBIT 2.2.30 Mirek FLUENT 1 April 15, 2006 17:22
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Error message on Cooper scheme mesh Mnu & Luc FLUENT 1 January 20, 2003 05:56
how to increase face mesh no.? Shankar FLUENT 4 August 9, 2002 15:48
