[ANSYS Meshing] Making ICEM model for Cylinderical object |
March 28, 2015, 00:57 |
sanjeet Limbu
Rep Power: 11 |
I have imported the multizone assembly of piston , cylindrical body and combustion volume as zones from .stp file. It generate the geometry- curves and point in ICEM on import model.
I started with blocking- 3D and did associate the curve and block On generating mesh I am getting very distorted surface, body. I tried doing the 2D blocking with swept , but was getting error- segmentation violation and whole file closed If there is any reference tutorial specific to the problem bellow - required kindly share Last edited by sanjeetlimbu; March 28, 2015 at 10:21. |
March 29, 2015, 22:18 |
sanjeet Limbu
Rep Power: 11 |
I tried doing the tutorial way - making the Geometry repair, setting global mesh size, volume mesh parameters and selecting the surface mesh setup and then generating the Mesh using compute to generate mesh
But I use it in ansys fluent I see error Physics: The inside is supposed to be fluid- pdf mixture in cellzone for partially premixed combustion case I am using the UDF to define the dynamic mesh - compression for the cylinderical vilume along the axis, the compression ratio will be 16.7. So I will use cutcell type deformation motion for Dynamic mesh Pl help to get it right - as I need solid body , but its hollow and show error Last edited by sanjeetlimbu; March 30, 2015 at 17:31. |
Display Modes | |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
[ICEM] Export half of the model from ICEM to CFX | enghamed | ANSYS Meshing & Geometry | 3 | July 30, 2010 11:23 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 05:55 |
IGES Solid Model for ICEM Tet Mesh | Samer | Main CFD Forum | 1 | September 17, 2008 13:33 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
