-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   PointWise Boundary Conditions (http://www.cfd-online.com/Forums/ansys-meshing/77492-pointwise-boundary-conditions.html)
skris2009 June 24, 2010 11:21
5 domains (faces) together make up a single circular inlet boundary in my geometry. I specify the inlet boundary condition for all 5 faces (together) and export the mesh to Fluent.
However in Fluent, I get 5 different faces as inlets. I need to specify a fully developed profile on this circular face, hence cannot use 5 sub faces to do so.
How can I combine these domains into a single boundary conditions (and not for the mesh)?
Thanks in advance.
antonio June 24, 2010 12:42
Hi.
I am using CFX but probably for fluent it`s similar.
If you´re using ansys-meshing you have to set the Selection Filter to Faces and select those faces you want to be part of that boundary . Then Right-click in the Model View and choose Create Named Selection, then enter some name for the Selection Name. The names assigned here will be transferred automatically to the solver.
Regards
