Point and Curve INFO in ICEM CFD
Old   June 27, 2010, 11:32
Default Point and Curve INFO in ICEM CFD
t_shirt
t_shirt is on a distinguished road
Hi All,
In ICEM CFD how can we take point and CURVE info as we took from GAMBIT?
Is there any option for that if yes please let me know under which cammand?
Thank you
t_shirt is offline   Reply With Quote
Old   June 28, 2010, 11:18
Default Programmers Guide?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Look in the programmers guide (under Help).
If you are more specific with the question, I can be more specific with the answer.
Here are a couple cut and pastes from the help...
ic_geo_surface_edges_incident_to_curve surfname curvename
Returns the edges in a triangulated surface which are incident to a given curve.
ic_geo_get_point_location name
Given the name of a point, returns its location.
ic_geo_crv_length crvs t_min [0] t_max [1]
Computes the arc length of a curve segment.
crvs list of one or more curves
t_min lower limit of segment (unitized
t_max upper limit of segment (unitized
return list of computed arc lengths
Notes:
t_min and t _max default to 0 and 1 respectively
For example usage see ftp://ftp-berkeley.ansys.com/pub/med...crv_length.tcl
There are also commands to do things with entities... etc.
ic_geo_cre_pnt_on_crv_at_par family name par crv
Creates a prescribed point on a curve at a parameter.
family family containing point
name name of created point
par curve parameter
crv name of curve to evaluate
return name of created point
Notes:
The specified point name may be modified to resolve name collisions.
If the function returns with the error status set, the result string will contain an error message.
For example usage see ftp://ftp-berkeley.ansys.com/pub/med...crv_at_par.tcl
PSYMN is offline   Reply With Quote
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
Define Point arrays on a curve selim FLUENT 0 June 4, 2008 10:30
Refinement from a point in ICEM CFD isabel CFX 0 December 17, 2007 06:58
Normal - Helical Surface m. malik Main CFD Forum 3 February 3, 2006 12:56
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
