[ICEM] Multiple Bodies
Like Tree2Likes
  • 2 Post By BrolY
Old   July 1, 2010, 09:07
Default Multiple Bodies
AB
BrolY will become famous soon enough
We are working on a new project. There are two parts on this project: a first one is a CFD study, and a second one is a thermic study. But the client want to solve this case by making one calculation with CFX. So, we have some questions:
1) I have attached a picture of what we would like to do with ICEM. We have a primary domain filled with fluid, and inside it, there is a solid part. The mesh must be a structured one (unfortunately). The fluid volume have to be meshed, and also the interior of the solid volume. We thought creating 2 bodies, one for the fluid volume (FLUID) and another one for the solid volume (SOLID). Is that possible to do mesh such a thing with a structured mesh?
2) The second question is about CFX. I know you are specialized with ICEM, but maybe you could answer to our question. How do we specify the two bodies when we export our model to CFX?
PSYMM' answer:
Yes, it is very easy... Block it out as if you were trying to capture the larger region (the fluid in this case). Then instead of deleting the solid blocks (putting them in the VORFN part), right click on the SOLID part and select Add to Part. The last icon in the DEZ is Add Blocking Material. Click that and then select the blocks within the solid region.
Now that you have two materials, Hexa will automatically project the faces between them to the surfaces. When you output to CFX, you will have two materials which it will automatically handle as two separate bodies. The 2 sided faces between them will be available for applying thermal transfer properties.
Jimmy123 and bluebase like this.
BrolY is offline   Reply With Quote
Old   July 2, 2010, 10:21
Default Did it work for you?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Thanks Alexandre,
Does this mean it worked for you?
Simon
PSYMN is offline   Reply With Quote
Old   July 5, 2010, 12:04
AB
We haven't tried it yet because the mesh is a little bit more complicated than we anticipated, but this is how we are going to proceed.
It should work
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Multiple domain/Multiple material problems... possible or not? Amiga500 OpenFOAM 1 April 14, 2010 16:32
Forces on multiple bodies jakaranda OpenFOAM 1 March 19, 2010 02:51
Mesh motion for two bodies siw CFX 0 April 8, 2008 05:20
Multiple reference frames? Moon Siemens 0 March 4, 2003 07:32
