3d catia models to gambit
Old   July 10, 2010, 06:39
Default 3d catia models to gambit
doki is on a distinguished road
I am trying to import a 3D catia model into gambit using .igs or .stp formats.
when I intend to mesh the geometry, I realize that there are a lot of small edge/faces in the geometry; which makes it impossible to generate a suitable mesh.
how can I fix the problem so that I could get proper mesh?
doki is offline   Reply With Quote
Old   July 12, 2010, 01:06
-mAx-'s Avatar
Maxime Perelli
Use merge tools (face and/or edge) and size functions.
STP format should be better than IGS
Old   July 12, 2010, 01:35
thanks
stp is sure better than igs.
I see what I can do, but there are a lot of such "broken" parts in the geometry, making it almost impossible to repair all of them manually.
Also, I do not know how to find all of these parts.
anyway, I should thank for your reply.
Old   July 12, 2010, 02:58
-mAx-'s Avatar
Maxime Perelli
if you know where your stuffs come from, you can attempt to correct them in CAD, and then reimport the STP file.
Can you post a picture from what give you problem
Old   July 12, 2010, 04:17
the CAD model does not show any problems in the native software. I guess it is a problem related to the extension.
3D catia models to gambit doki FLUENT 14 July 17, 2010 11:21
[GAMBIT] Catia to Gambit sbajpai ANSYS Meshing & Geometry 3 January 9, 2010 12:44
Catia to Gambit sbajpai ANSYS 0 January 6, 2010 21:18
catia to gambit sulilatu FLUENT 1 December 5, 2006 22:31
Import 3D models to GAMBIT from 3DStudio Freeman FLUENT 6 October 12, 2005 13:14
