Home > Forums > ANSYS Meshing & Geometry
Immersed objects
Old   July 13, 2010, 20:30
Question Immersed objects
Yarzar
ATOTA is on a distinguished road
HI,
I need help in modeling bodies in fluid volume. I used gambit before and all I had to do was subtract the object from the fluid domain. Now, I am using ANSYS workbench 12.1. I tried the enclosure command but I am not so sure how it works. How could I make the object hollow and the domain meshed ?
Thank you
ATOTA is offline   Reply With Quote
Old   July 14, 2010, 06:30
Matthias Voß
mvoss is on a distinguished road
hi,
use the boolean body operation (subtract) after freezing everything. before that you have to create your exterior and your body-to-subtract. you also can slice a body by other bodies, ending up in lot of bodies and then just simply delete everything you don´t need (body operation delete).
neewbie
mvoss is offline   Reply With Quote
Old   July 14, 2010, 13:28
Default Multibody
Debashish Saha
debashish is on a distinguished road
I am a new user of Ansys and I need to know how can I join tow body in 3D? I knew how to do that in SOLIDWORKS but here it does not work in that way.
Can anyone please help me?
Regards,
Debashish
debashish is offline   Reply With Quote
Old   July 15, 2010, 14:36
Yarzar
Thank you very much !
Old   July 15, 2010, 20:52
Default Join/union or MultiBody Part?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Debashish,
Do you want to join two bodies into a single body or make a multi-body part so they are still meshed as two bodies, but with conformal mesh where they meet?
Simon
PSYMN is offline   Reply With Quote
Thread Tools
Trackbacks are On
IcePak network objects in parallel solver Alexey FLUENT 1 December 25, 2013 09:32
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 06:14
Warning when I add my objects Xu Phoenics 0 November 21, 2008 13:30
Immersed Boundary Conditions Mahibooswami Main CFD Forum 2 June 19, 2003 19:10
immersed boundary method with unstructured mesh x.zhang Main CFD Forum 0 August 25, 2002 21:57
