-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Turbofan engine model meshing in gambit (http://www.cfd-online.com/Forums/ansys-meshing/78466-turbofan-engine-model-meshing-gambit.html)
vincentryan July 22, 2010 08:33
1 Attachment(s)
I have created simple turbofan engine model in Gambit, while messing my model i have getting folowing error
"NUMBER OF INTERVALS ON MESHED EDGES OF FACE DOES NOT ALLOW MESHING USING A SCHEME OF MAP"
here i have attached my gambit modle? how and what type of mesing should i have to use?and how can i create inlet and outlet biundary conditions?
-mAx- July 23, 2010 01:15
1 Attachment(s)
You are trying to mesh your surface on the fly with Map, and of course it is not possible.
Split your domain into several mappable subdomains, like this for instance
Attachment 4179
vincentryan July 23, 2010 06:08
to create several mappable subdomains, i have to create edges with the corresponding vortex points? are any other method is available to split domain into sevral mappable subdomains?
-mAx- July 23, 2010 06:48
Split surface with vertex.
you can also split with edges, or with surface (but here you need real entities)
vincentryan July 24, 2010 14:16
1 Attachment(s)
I have created several subdomains as you have shown in the picture.
how to mesh this subdomains? shall i to create each subdomains as a face or a single face to mesh?
-mAx- July 26, 2010 01:00
all the surfaces should be mappable (quad)
vincentryan July 26, 2010 17:10
1 Attachment(s)
while meshing domain which is not meshed in the figure i am getting the error "NUMBER OF INTERVALS ON MESHED EDGES OF FACE DOES NOT ALLOW MESHING USING A SCHEME OF MAP"
is it correctly meshed the remaining domains?
can u give some example and solution manual for creating, mapping and meshing domains in gambit?
-mAx- July 27, 2010 01:09
the top sudomain is already meshed with 11 nodes on the lower edge.
Now on the last subdmain you want to mesh, I count 22 nodes on both edges (opposite to the one common with the top meshed subdomain).
Mapp Mesh algorithm isn t able to project the 11 nodes on the 2 other opposites edges, since they are already meshed (with 22 nodes).
So delete all the edges which are not common to meshed subdomains (the 3 lower meshed edges with blue symbols)
vincentryan July 27, 2010 02:30
ok if i delete the all edges which are not common to meshed domains then how can i mesh the domain?
-mAx- July 27, 2010 03:09
surface/mesh :)
