July 22, 2010, 08:33 |
Turbofan engine model meshing in gambit
vincnet
I have created simple turbofan engine model in Gambit, while messing my model i have getting folowing error
"NUMBER OF INTERVALS ON MESHED EDGES OF FACE DOES NOT ALLOW MESHING USING A SCHEME OF MAP" here i have attached my gambit modle? how and what type of mesing should i have to use?and how can i create inlet and outlet biundary conditions? |
July 23, 2010, 01:15 |
Maxime Perelli
Rep Power: 41 |
You are trying to mesh your surface on the fly with Map, and of course it is not possible.
Split your domain into several mappable subdomains, like this for instance Sans titre.png
In memory of my friend Hervé: CFD engineer & freerider |
July 23, 2010, 06:08 |
vincnet
to create several mappable subdomains, i have to create edges with the corresponding vortex points? are any other method is available to split domain into sevral mappable subdomains?
July 23, 2010, 06:48 |
Maxime Perelli
Rep Power: 41 |
Split surface with vertex.
you can also split with edges, or with surface (but here you need real entities)
July 24, 2010, 14:16 |
vincnet
I have created several subdomains as you have shown in the picture.
how to mesh this subdomains? shall i to create each subdomains as a face or a single face to mesh? Last edited by vincentryan; July 24, 2010 at 14:43. Reason: wrong entry |
July 26, 2010, 01:00 |
Maxime Perelli
Rep Power: 41 |
all the surfaces should be mappable (quad)
July 26, 2010, 17:10 |
vincnet
while meshing domain which is not meshed in the figure i am getting the error "NUMBER OF INTERVALS ON MESHED EDGES OF FACE DOES NOT ALLOW MESHING USING A SCHEME OF MAP"
is it correctly meshed the remaining domains? can u give some example and solution manual for creating, mapping and meshing domains in gambit? Last edited by vincentryan; July 26, 2010 at 17:15. Reason: information added |
July 27, 2010, 01:09 |
Maxime Perelli
Rep Power: 41 |
the top sudomain is already meshed with 11 nodes on the lower edge.
Now on the last subdmain you want to mesh, I count 22 nodes on both edges (opposite to the one common with the top meshed subdomain). Mapp Mesh algorithm isn t able to project the 11 nodes on the 2 other opposites edges, since they are already meshed (with 22 nodes). So delete all the edges which are not common to meshed subdomains (the 3 lower meshed edges with blue symbols)
July 27, 2010, 02:30 |
vincnet
ok if i delete the all edges which are not common to meshed domains then how can i mesh the domain?
July 27, 2010, 03:09 |
Maxime Perelli
Rep Power: 41 |
surface/mesh
how do i model a brake disc in gambit? | joshie | FLUENT | 1 | September 16, 2009 08:43 |
SketchUp 3D model import to Gambit or Fluent | Steve Johnson | FLUENT | 0 | February 8, 2009 14:21 |
turbulence model in internal combustion engine | George | Main CFD Forum | 0 | December 4, 2006 18:01 |
Creating geometry & meshing using Gambit | Ray | FLUENT | 3 | August 1, 2000 03:30 |
