August 9, 2010, 07:02 |
prismatic layers
vinay
Rep Power: 15 |
hi,
can anyone tell me how prismatic layers are related with aerodynamic conditions like pressure,temperature,velocity etc. |
August 9, 2010, 10:49 |
AB
Rep Power: 21 |
The prismatic layers are created to capture the boundary layer.
The boundary layer depends on your aerodynamic conditions (The number Y+ is usually used to calcul the height of the boundary layer). The most important one is the velocity. You can google it for more details about the Y+ formula. |
August 10, 2010, 00:28 |
vinay
Rep Power: 15 |
Hi Alex,
I have got the formula to solve it.but i didn't understand the term "REF. LENGTH".please guide me. Thank you, |
August 10, 2010, 04:41 |
AB
Rep Power: 21 |
The reference length depends on your geometry.
For example, if the geometry is a pipe, you would use the diameter (or the radius) as the reference length. Got it? |
August 10, 2010, 05:12 |
vinay
Rep Power: 15 |
yes i got it.Do u know about KARMAN and upsweep discretization in ICEM CFD TETRA?
Please give some suggestions. thank you, |
August 10, 2010, 05:52 |
AB
Rep Power: 21 |
I'm sorry, I can't help you on that. Maybe someone else on the forum?
Good luck ! |
August 10, 2010, 15:48 |
Simon Pereira
Rep Power: 47 |
vinuaero you may be putting too much pre-thought into it...
Basically, you just want your prism layer to be thicker than your boundary layer so you can more efficiently capture the boundary layer profile. Run your Y+ Calcs, etc. (they are useful for the first cell height) but at some point you just need to put as many prism layers on there as you can and send it to the solver. Then look at the solution with the grid visible. Is the majority of the boundary layer (slower flow) within the prisms? If so, is it relatively close or are your prisms much thicker than they needed to be (did you put excess work and sacrifice quality to get prisms you didn't need...? Learn for next time.) Does it look like your prisms are not thick enough to capture the viscous boundary layer profile? Most CFD analysts are really repeat users (repeat offenders) who learn from previous runs and generate better meshes based on understanding a certain class of problem. You probably won't know exactly how thick your prism layer should be until you make a few runs on that type of configuration and get a feel for it... Just make sure to observe how your results relate to your mesh and learn as you go. Most mature customer sites have meshing guidelines for various classes of models which they guard closely as trade secrets. You may also want to run some mesh refinement studies to see if your mesh is fine enough that the results are not dependent on them. |
[snappyHexMesh] SnappyHexMesh doesn't succeed in adding several layers | eti0123456789 | OpenFOAM Meshing & Mesh Conversion | 5 | April 9, 2013 02:36 |
Boundary layers in Gambit | Ian | FLUENT | 3 | March 3, 2012 09:54 |
SST model and boundary layers | Rodrigo Basniak | CFX | 7 | March 27, 2008 14:19 |
Creating inflation layers for elbow with airfoil ! | Aplus | CFX | 1 | March 13, 2006 22:22 |
Effects of numbers of layers in the BL zones | CFD Rookie | Main CFD Forum | 2 | January 30, 2004 10:43 |
