-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Problem with coordinates file (http://www.cfd-online.com/Forums/ansys-meshing/79260-problem-coordinates-file.html)
Fabio August 18, 2010 06:10
Hello all, i'm new to this package and i'm doing some tutorials starting from the basics. All went well untill i found an exercise where i have to create a 3D curve starting from a coordinates file provided. When i read the file i always get the same "error reading coordinates file" if i try to generate anyway by RMB i go on "show errors and warning" and i can see the error "Duplicate coorinates found in coordinates file" this on line 3
1        1        0        0        0
1        2        15        93.17485624        0
1        3        30        180          0
1        4        45        254.5584412        0
1        5        60        311.7691454        0
1        6        75        347.7332975        0
1        7        90        360          0
1        8        105        347.7332975    0
1        9        120        311.7691454        0
1        10        135        254.5584412        0
1        11        150        180          0
1        12        165        93.17485624        0
1        13        180        4.41053E-14        0
1        14        195        -93.17485624        0
1        15        210        -180          0
1        16        225        -254.5584412        0
1        17        240        -311.7691454        0
1        18        255        -347.73329750        0
1        19        270        -360          0
1        20        285        -347.7332975        0
1        21        300        -311.7691454        0
1        22        315        -254.55844120        0
1        23        330        -180          0
1        24        345        -93.17485624        0
1        25        360        -8.82107E-14        0
someone could give me some advice? I' ve started thinking about how the file is formatted or other strange things, it should open and work, but it isn't.
Fabio August 21, 2010 15:43
Easy help
A very simple thing that could help me, would be if someone copy/paste the data i provided in a .txt file, and to open it in designmodeler on Ansys, to see if ti gives the same error.
Thanks in advance if someone will do it.
