[ICEM] Error in opening the geometry
Old   August 20, 2010, 10:06
Default Error in opening the geometry
AB
BrolY will become famous soon enough
I have a problem when I try to open my project. Here is the error message:
Current Coordinate system is global
Loading project settings file: .../2008_VENTILO_1.prj...
Loading geometry file "2008_VENTILO_1.tin"
error in 2008_VENTILO_1.tin
can't read surface model
Loading domain "2008_VENTILO_1.uns" .
The mesh still works, but I can't have access to the geometry anymore.
How can I fix that and have my geometry back?
Thanks for your help,
AB
BrolY is offline   Reply With Quote
Old   August 20, 2010, 10:13
AB
By the way, I'm using ICEM 12.1 and working with linux.
Here is another error message I found in the linux command box:
new_pre_point: interface_fluid/interface_fluid_3/interface_fluid_3/interface_fluid_3/interface_fluid_3/INTERFACE_FLUID_3.1162 is not a valid name, changing to interface_fluid/interface_fluid_3/interface_fluid_3/interface_fluid_3/interface_fluid_3/INTERFACE_FLUID_3.1162
variable \ufffd\ufffd undefined
while executing
"projlib_interface__33 load_model "2008_VENTILO_1.tin" 0 0 0"
("eval" body line 1)
invoked from within
"eval $projlib load_model \"$file\" $load_tetin_triangle_tolerance $tetin_try_binary $keepr $args"
Thanks
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
icem cfd geometry tin file not opening cfx 10 c mayur CFX 2 July 10, 2007 02:57
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
