[GAMBIT] Volume mesh error?
Old   August 23, 2010, 17:09
Default Volume mesh error?
seyedashraf's Avatar
Omid Seyedashraf
seyedashraf is on a distinguished road
Send a message via AIM to seyedashraf Send a message via Yahoo to seyedashraf
Modeling a somewhat difficult to model _Specially in gambit _, 3D weir
now in the last step , meshing the volumes it Gambit shows this error
any suggestions?
seyedashraf is offline   Reply With Quote
Old   August 24, 2010, 01:06
-mAx-'s Avatar
Maxime Perelli
If you read the error message, it says that you have surface mesh with high skewness.
Check where are those surfaces and fix the problems.
Old   August 24, 2010, 02:27
Omid Seyedashraf
i have read that
didnt know how to find those faces
there are lots of faces in the model
Old   August 24, 2010, 02:37
-mAx-'s Avatar
Maxime Perelli
in Gambit go to examine Mesh.
Since volume meshing has failed, you can go to examine mesh and choose 2d element.
Then set the lower value to 0.9 for instance, it will display all the 2d elements with skewness over 0.9
Sometimes Gambit mentions which surfaces give you problems (in the error message you got, try to see if gambit mentionned any surface mesh failed or something like this).
Old   August 26, 2010, 07:15
Omid Seyedashraf
ok
ill try this
thanks to the tips
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
