[GAMBIT] Need some guidance for meshing
Old   August 24, 2010, 02:03
Default Desperately need help on meshing problem
VLKOH
lalula2 is on a distinguished road
Hi all,
I was trying to simulate a model for air flow over an outdoor deck as you can seen on the image file on the link below.
http://img411.imageshack.us/img411/1381/geometry.png
I was trying to mesh the whole volume with hexahedral mesh. But unfortunately it failed. Anyone expert here kind to teach me some strategic to mesh this volume?
Thanks.
Regards.
lalula2 is offline   Reply With Quote
Old   August 24, 2010, 04:52
VLKOH
Hi all,
I decomposed my volume into a smaller size as shown on picture below.
http://img178.imageshack.us/i/meshx.png
However i have problem to mesh the small opening located below. the opening size are 29m x 0.4m. I got the message from Gambit as shown below:
ERROR: Volume 8 could not be meshes with a scheme of cooper because the previously meshed edges on one of the faces is unacceptable.
Any method to tackle this problem? Any suggestion are welcome.
Thanks.
Regards.
Last edited by wyldckat; September 3, 2015 at 16:16. Reason: disabled embedded images
Old   August 25, 2010, 15:43
Arash
arash_7444 is on a distinguished road
did you try size function for your geometry, for example use "approximately size function"
i dont know if it is work for your problem or not....
arash_7444 is offline   Reply With Quote
Old   August 26, 2010, 02:27
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
the problem should come from an edge wich is already meshed, but don't match the element count of your source.
Basically if you have a rectangle and you mesh the smallest side with 10 nodes, and the other (opposite) with 11, then you have a problem
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Hi first post - some guidance skinduptruk OpenFOAM 0 October 4, 2009 12:38
Need guidance and help Narenmd CFX 3 September 25, 2009 05:27
need guidance.......... ashitkumar FLUENT 0 February 15, 2008 07:21
Guidance for a project Hemalatha FLUENT 1 December 28, 2005 04:15
Guidance toward convergence Keith Gray Main CFD Forum 0 December 27, 2002 13:50
