Why only one prism layer generated (ICEM)
Hi Everyone,
I am trying to generated Tetra+prism mesh using a fairly complex geometry using ANSYS-ICEM 12.1. I set the initial thickness of prism layer as 0.1, ratio is 1.1, and number layer as 4, while only one layer was generated. I tried another method: generate one layer of Prism, then splited it into 4 layers. It worked. While When I was importing this mesh into cfx, an error message came out: 2010/08/25 22:01:58 GTMAPI::importMeshIntoModel - There was a problem importing the mesh from the requested file. The importing process reported the following problem: Unable to import mesh: Invalid local face number (0) for element 2317277 in 2D region PART_BLADE_WEDGE_LIQ_SOLID_1. While when I imported the mesh file which do not contain prism layer, it's no problem. Please help me to solve the problems! Thanks a lot! |
