Boundary Layer
Old   March 16, 2009, 06:30
Default Boundary Layer
Fabio is on a distinguished road
Hi all, i'm studying a 3d duct flow i got both Tgrid and Gambit, is there anyway to do a y^{+} refinement near the wall boundaries?
The gemetry has some sharp edges and create a 3d boundary layer ad usual is very difficult i got in Tgrid some intrfaces issues when back to Fluent.
If necessary i shoul post some images of my domain.
Thanks for any answer.
Fabio is offline   Reply With Quote
Old   March 19, 2009, 03:09
I will try to put the question in a more easy way, using Gambit or Tgrid is possible to create a good mesh for a viscous fluid simulation without using the Boubdary Layer tool?
I got problems with this tool due to internal corners less than 45°
Old   March 20, 2009, 05:46
Adam S is on a distinguished road
I for one donīt understand what you mean. A pic may help.
Adam S is offline   Reply With Quote
Old   March 20, 2009, 06:33
Hi and thanks, this is the image http://img16.imageshack.us/img16/922/flap3.png is a flap inside a tube,it's a 3d case i'm trying to run a viscous fluid simulation, but i got problems with mesh generation aronud the flap due tot the small angles of the geometry.
If i use a 3d boundary layer i got poor skewness and i useless even to try run the simulation, so i'm thinking to get a mesh good for a viscous case without usin BL but with an eye to y^{+} parameter.
I hope now is more clear if not i try to do best.
Old   March 20, 2009, 06:51
your tube is circular?
how is your meshing procedure?
you have notion of icem hexa blocking?
Old   March 20, 2009, 10:11
Yes the tube circular.
First i have meshed the edges to get a finer mesh where required, the i have meshed the surfaces with Tri/Pave because other tipes are not applicable or give poor skewness, then in BL panel i use:
Algorithm = Uniform
First row = 0.1
Growth factor = 1.1
Rows = 4
Depth = 0.46
Internal contimuity = Yes
Wedge conrner shape = No
Transition pattern = 1:1
i got those results
http://img21.imageshack.us/img21/6978/extflap3.png http://img22.imageshack.us/img22/3559/symflap3.png
I now Gambit and Tgrid but never used ICEM
Old   March 23, 2009, 04:57
meshing around this flap isnīt easy. and my knowledge about gambit isnīt best, sorry. what does "wedge corner shape" do?
try to adjust the parameters for the specific corner to get better result.
Old   March 23, 2009, 05:07
Well actually i'm working around the flap with size function, skewness has improved but i need to tune the parameters in order to not get too much cells in mumber.
Anyway if you got some tricks about ICEM tell me, maybe some friends with that program could help me.
Thanks anyway
Old   April 1, 2009, 05:37
Even if i got a better skewness seems that much work is needed, so my final question is: with a finer mesh near the wall boundries without using the BL tool is possible to get convrgence in a viscous fluid case?
Thank to anyone who will answer.
Old   September 5, 2010, 00:02
Default HI
hassan
hassan79 is on a distinguished road
HI , Good Day
for you case
First row = 0.1
Growth factor = 1.1
Rows = 4
Depth = 0.46
I aske about any relation ship between first row and groth factor and now ofv row and depth
my case it is expansion pipe i fond formala from gird spacing calculator to find first row ? iam not sure about this formal it is correct or no ?
could u help me
Re 8112
d= 0.0254
D = 0.09525
fluid = air
temprature inlet = 20
constant heat flux = 720
i want to calculate surface nusel no
thank u
Hassanhayawi@hotmail.com
hassan79 is offline   Reply With Quote
Old   September 6, 2010, 09:34
Hello, that formula is reffred to a fal plate in free stream, i don't remeber if is needed som sort fo correction factor to apply the results in a duct case.
Anyway what i don't know with which number have you filled the y^+ field, it makes difference for the turbulence model that you could use appropriately.
Which program are you using to create your mesh? In the Gambit manual there is description for every factor involved in the boundary layer creation.
Old   September 6, 2010, 09:52
Default hi
  #12
hassan
i use gambit ? i want simulate heat transfer in expansion pipe with turbulent fluid flow i need to calclate surface nusselt no my problem in y+ i make bondary layer but i get y+= 30 how can i maked y+=1
how can to optain first row and growth factor no of row to get y +=1
Old   September 6, 2010, 11:36
when you now have y+ = 30 then simply refine your mesh.
in general you can not adjust it before, cause itīs depending on model size and flow conditions.
in your (simple) duct geometrie you can pre-calculate it analytically.
Old   September 6, 2010, 12:11
If i rember well is possible to have a preview of the boundary layer that will be created and the relative y+.
Anyway i have found this paper maybe it helps http://www.iaeng.org/publication/IME...p2165-2170.pdf
Boundary conditions for turbulent boundary layer Thomas FLUENT 1 June 17, 2008 05:14
boundary conditions for boundary layer flow A. Al-zoubi CFX 0 November 3, 2007 07:11
boundary layer Fer Main CFD Forum 0 November 23, 2005 03:43
Boundary Layer? P.I FLUENT 0 September 17, 2003 11:27
Boundary layer sameer mohrir FLUENT 3 August 19, 2000 14:16
