-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] replay file with different geometry (http://www.cfd-online.com/Forums/ansys-meshing/79855-replay-file-different-geometry.html)
marting September 7, 2010 02:17
Dear all,
I created the geometry of a pump rotor in ProE, copy/paste to get the surface all in one, added this surface to a layer and exported this surface to a tetin file.
The attributed surface mesh in the recorded ICEM-replay file looks like
ic_set_meshing_params surface {ROTOR/2842 ROTOR/2841 ROTOR/2840)
As u can see, the rotor still consists of several surfaces.
Is there a possibility to get the surface mesh attributed to the part ROTOR which shows up in the ICEM model tree and independent from the ROTOR/xy ??
Thank you for your help!
cheers, martin
marting September 8, 2010 10:46
got it!
Instead of picking the surfaces of a part separately, one should use the "Part Mesh Setup".
It s the
ic_geo_set_family_params ROTOR no_crv_inf prism 0 emax 9.0 ...
command in the replay file.
martin
