September 13, 2010, 08:12 |
Overlapping elements on big radius
There is a problem with overlapping elements on big radius (pic1).
I tried: 1. split block on radius (pic2) 2. assosiate edges and vertex with radius curve (pic3) but there is no result How can I fix it? Thanks for your help |
September 14, 2010, 08:06 |
jeevan kumar
hello gajemon,
This can happen with improper extraction of curves from surfaces, or with bad geometry. you can try 1. check the curves and the surfaces at that location where you have problem, try to extract cruves once again. 2. if it doesnt work you can try using interpolate option in the face assotiation. image attached, and select the two alternate faces where you have problem. thank you 1.JPG |
September 21, 2010, 15:53 |
Projection Limit
Simon Pereira
Rep Power: 47 |
The best fix for curves and surfaces not quite lining up is turning on "Settings => Meshing Options => Hexa/Mixed => projection limit" This will interpolate just across the gap and not for the entire face...
However, this problem looks more like overlapping. It is pretty strange. Oh well, I can't tell from here. Try the projection limit and other suggestions. If it still doesn't work you could post your model (or send it to me privately) and I could take a look when I have time. Or you could send it in to techsupp@ansys.com |
[ICEM] Overlapping elements | Anorky | ANSYS Meshing & Geometry | 6 | November 6, 2017 09:22 |
elements, nodes and faces | Andy | CFX | 10 | July 7, 2013 23:40 |
[ICEM] How to eliminate overlapping elements? | ringtail | ANSYS Meshing & Geometry | 5 | October 5, 2010 20:22 |
Penetrating elements in extruded mesh | Michael P | CFX | 2 | May 20, 2005 09:06 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
