-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [GAMBIT] how hexahedral mesh is done (http://www.cfd-online.com/Forums/ansys-meshing/80356-how-hexahedral-mesh-done.html)
harry_dhiman September 23, 2010 06:33
hello,
i am very new to this field. i am working on centrifugal pump. i was told to to do hexahedral meshing of the pump. since it's casing, water passage and impellor are not simple geometry(i.e. with continuing changing cross section).
wat can i do abt it.
harry_dhiman September 23, 2010 06:35
urgent plz reply
qxtxdy October 1, 2010 03:09
Originally Posted by harry_dhiman (Post 276281)
hello,
you may have to use ICEM. You may find that it is hard ,even impossible to use GAMBIT to do hexahedral meshing for a complicated geometry
harry_dhiman October 1, 2010 04:56
thankx for reply
can u please tell me wat is effect & meaning of equisize skew and aspect ratio in gambit.
qxtxdy October 1, 2010 08:48
Originally Posted by harry_dhiman (Post 277388)
thankx for reply
they are just two aspects of evaluations of the grid you mesh.you had better learn from the GAMBIT help
harry_dhiman December 10, 2010 08:44
i am working on centrifugal pump. the solution of the pump is not converging. the graph that is plotted during iterations shows very fluctuating lines. wat can be the problem. kindly reply.........
