-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Icem CFD on Linux (http://www.cfd-online.com/Forums/ansys-meshing/80443-icem-cfd-linux.html)
mechanicaldesign September 26, 2010 14:16
Icem CFD on Linux
Hi ,
I have a question which refer to launch Icem CFD on linux. The version of Icem CFD is from ANSYS 12.1.
My question is: what command line to use in Linux to launch ICEM CFD, or where is the correct path from were I can launch it ?
Thank you very much in advance for your advice.
Best regards:cool:
hellorishi September 29, 2010 06:56
Maybe you could add the following line to your ".bashrc" or ".alias" or whatever might be your start up script.
alias icemcfd='/usr/ansys_inc/v121/icemcfd/linux64_amd/bin/icemcfd'
mechanicaldesign October 1, 2010 14:47
Hi hellorishi,
Thank you for your advice. I donīt try yet command recommended by you, but what is the effect if doesnīt work ? Have influence the modification in other module beside of icemcfd ?
Thank you for advice. I will keep in touch if it work.
Best regards
hellorishi October 1, 2010 17:44
As far as I know the command will not have any adverse effect.
If it does not work try exploring your system with command line or some sort of file browser. Which Linux are you using ?
mechanicaldesign October 2, 2010 12:45
Hi hellorishi,
I using Ubuntu 10 64 bit and CentOS 5.4 64 bit.
Best regards.
snehilbuxy January 6, 2012 07:18
Hi, I am using Fedora 16 x64. When i run
$ /ansys_inc/v121/icemcfd/linux64_amd/bin/icemcfd
this comes up..
ICEM_ACN is /usr/ansys_inc/v121/icemcfd/linux64_amd
ANSYSLIC_DIR is set to /usr/ansys_inc/shared_files/licensing
args
and it just sits there.. what am i missing ?
Quaxi February 14, 2013 11:39
quit old thread, but first hit on google...
on my system (fedora 18) installing some fonts (as in the installation guide) helped with this problem:
yum install xorg-x11-fonts-ISO8859-1-75dpi.noarch xorg-x11-fonts-cyrillic.noarch
