[ICEM] How to eliminate overlapping elements?
Old   March 18, 2010, 00:29
Default How to eliminate overlapping elements?
ringtail is on a distinguished road
Hi, everyone
I have generated an O grid mesh, which is showed in the following picture.
When I checked the mesh quality, I found there were some overlapping elements. Who can help me eliminate the overlapping elements?
thanks.
ringtail is offline   Reply With Quote
Old   April 21, 2010, 18:44
Default Should not do that...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
That looks pretty ugly... Hexa should not do that.
Can I see the files?
Simon
PSYMN is offline   Reply With Quote
Old   April 21, 2010, 23:51
Simon
Hi, Simon.
That is my first try to mesh a 2d cylinder. And now i know why it looks so ugly: i have used "smooth mesh globally" function.
Simon, can you help me about my current trouble :how to refine the mesh?
I have described the problem:
http://www.cfd-online.com/Forums/ans...mputation.html
Generally speaking , i mean that i want to coarsen the mesh but the mesh should satisfy the following demand:
1. the first layer mesh should be close enough to the wall to make sure y plus approximate to one.
2. aspect ratio of mesh should not be big in order to be true of FLUENT's limitation.
thanks very much.
Old   September 24, 2010, 16:30
Zdeth
zdeth is on a distinguished road
did you find a fix to these overlapping nodes? I'm having a similar problem where it just kinda goes up and folds over on its self..
zdeth is offline   Reply With Quote
Old   September 25, 2010, 09:19
I had smoothed the mesh using ' global smooth'. This was the reason why there were so many overlapping nodes...
Old   October 5, 2010, 19:22
Default All set?
PSYMN's Avatar
Simon Pereira
Hey Ringtail are you all set on this... I can't tell much from your image. I don't even know if you have an Ogrid. I would need better images or the actual files to help any more on this one.
Best regards,
Simon
elements, nodes and faces Andy CFX 10 July 7, 2013 22:40
MESH ERROR Francesco - University of Florence, Italy CFX 2 April 24, 2008 11:10
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
