3D mesh starting from a 2D
Old   October 7, 2010, 18:22
Question 3D mesh starting from a 2D
Alex
bruxellois is on a distinguished road
Hi everybody,
Is it possible to get a real 3D mesh starting from a 2D mesh (fluent or gambit) or an axisymetric geometry from OpenFoam?
Best regards.
bruxellois is offline   Reply With Quote
Old   October 8, 2010, 01:43
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Yes you can with gambit.
From 2d mesh you can sweep or revolve faces with mesh option, meaning that geometry AND mesh will be transformed.
If you want to import your mesh from OpenFOAM, then I assume you need to use the utility foamMeshToFluent. (but I never used it). For sure fluentMeshToFoam & fluent3DMeshToFoam work well
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
3D mesh starting from a 2D bruxellois OpenFOAM 14 August 25, 2011 11:56
[Salome] unv mesh corrupted after createPatch maddalena OpenFOAM Meshing & Mesh Conversion 1 February 18, 2010 07:43
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
hex mesh by starting from a group of point Giulia Valerio FLUENT 0 November 8, 2007 04:47
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
