meshing a spherical surface
Old   October 11, 2010, 04:44
Post meshing a spherical surface
Mansureh is on a distinguished road
hi every body
can anybody tell me, how can I mesh a spherical surface with a structured hexa grid in gambit?
thanks, any help will be appreciate
Mansureh is offline   Reply With Quote
Old   October 19, 2010, 13:54
Default Ogrid.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You will need to subdivide it into at least 6 surface patches... But then you will have issues with the volume mesh at the "corners".
If you subdivide the volume into 7 blocks (6 surface aligned blocks plus a central block), you could create an Ogrid and that would solve all the problems..
In ICEM CFD Hexa you can do it all in a single operation and without subdividing the geometry...
PSYMN is offline   Reply With Quote
[DesignModeler] Sweeping or surface meshing in enclosure? Edu-R ANSYS Meshing & Geometry 9 January 23, 2013 13:41
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Surface Repair for Meshing Andy R Main CFD Forum 13 May 3, 2008 14:33
meshing for surface ship flow boris FLUENT 0 April 24, 2002 20:27
meshing when surface vertex are known ml Siemens 1 March 10, 2002 17:51
