October 14, 2010, 02:59 |
Concept behind Y+
siddharth jain
hello all,
can anybody explain me the concept behind Y+...........how do we set the value of Y+.....and how we calculate ? what if the value of Y+ is very large or very less........? thanx........... |
October 15, 2010, 05:36 |
Hi sidspark12,
all depends on your turbulence model. Wrong y+ parameters can(!) lead to wrong functioning of turbulence model (but, not so easy, as usual - everything depends on everything). Let's say that one general approach (but not the rule) for y+ for two-equation models is y+ ~ 1 for k-w y+ ~ 30 for k-e Of course, it is quite difficult to have constant y+ in all the surfaces, but usually you can try to be near to that values. For y+ information you can check in solver's manuals - like in CFX manual or Fluent manual. Regards, DST |
October 15, 2010, 07:03 |
siddharth jain
Hello DST
thanx...a ....lot... Right now i am solving the case of FRANCIS TURBINE. for that i am using k-e model......and the value of y+ is around 12........now in my case the value of y+ is not same for every element because of the bldae design. .........now as u said in k-e model the value of y+ is near 30..........so how should i improve the value of y+.......? after this i will also solve the same case with k-w model........ thanx...... |
DPM parcel concept | raba_eto | FLUENT | 7 | September 18, 2015 02:51 |
eddy dissipation concept + infinitely fast chemistry | mabinty | OpenFOAM Running, Solving & CFD | 4 | September 17, 2012 04:55 |
eddy dissipation concept | sisilxp | FLUENT | 5 | May 13, 2004 05:13 |
Open Challenge for Concept of Turbulence | K.K.J.Ranga Dinesh | Main CFD Forum | 2 | June 3, 2003 13:41 |
What is the concept of.. | Sharad Dugad | FLUENT | 2 | January 19, 2002 12:12 |
