October 17, 2010, 07:34 |
ICEM meshing problem
newansysuser
I am new to ICEM CFD meshing, what I want to do is really simple, my model is 1980mm*75mm*5mm, which is long but small area on two sides(see attachment) I have tried cfx-mesh, but use tretra , there are too many elements in the body, because I want at least 20 nodes on the 5mm length. So now I tried to use hex meshing in the ICEM CFD, but it turns out my meshing is wrong. first I imported my model to ICEM, blocking it, set different blocks to cut the useless blocks. Then associate all the edges to curves , move some vertex , set the global meshing, and premesh refined the nodes on the 5mm length, premesh again converted it to unstruct and choose ANSYS cfx solver and output as a cfx5 file. THen in workbench , i just did what i used to did after the workbench cfx mesh,, like adding boundary and run it. But after I imported cfx5 mesh and run , in post processing, the result is wrong, and even sometimes , solver told me errors who can help me? |
October 27, 2010, 15:59 |
Tested and it all looked OK.
Simon Pereira
Rep Power: 47 |
Ok, I took a look at your files.
You didn't associate the back edges... (note they are showing as black nodes here instead of green, this is with the mesh display option "as dots" on.) xyq_online_01.jpg But that shouldn't stop you. So I went to CFX and imported the CFX5 file... I had no problems there either. xyq_online_02.jpg You didn't give me enough info to reproduce the rest of the test in order to get your error messages, etc. Perhaps you should get some screen shots with the errors in CFX and post your question on the solver thread. It is probably not a mesh question... UNLESS... Are you meaning to do a near 2D mesh? In that case, CFX users generally just do a single element thru the thickness. Or better yet, do it as a 2D model and then output in the fluent format. When CFX imports FLuent 2D mesh it automatically extrudes it... |
October 27, 2010, 16:04 |
Chinese?
Simon Pereira
Rep Power: 47 |
One other thought... There were some Chinese characters in the file path name... I replaced those with English characters because they messed up the project a bit... There is a slim chance that those characters are the problem. Try again with English letters just to be sure.
October 28, 2010, 01:59 |
newansysuser
one quick question, we don't have inflation layers to add in ICEM right? How to accurately control or calculate the wall condition?
October 28, 2010, 09:35 |
OGrid?
Simon Pereira
Rep Power: 47 |
Of course ICEM CFD has inflation layers... In unstructured Tetra, you would insert prism. For MultiBlock Hexa, you would put in an OGrid... There are tonnes of posts about this, but you should probably pull out a tutorial to learn the basics of how to apply it. Once you know how, it is easy and automated. Simon |
October 28, 2010, 10:09 |
newansysuser
ok, I will try to find tutorials about inflation layers.
I have sent you the .cfx, can my model run correctly on your pc? |
ICEM keyboard problem in linux | gravis | ANSYS Meshing & Geometry | 4 | February 28, 2020 09:23 |
[ICEM] Meshing problem from ICEM CFD to Fluent | cfdonlinederafa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:16 |
IGES/IGS format geometry file for icem meshing | littlelz | Main CFD Forum | 0 | May 27, 2008 18:24 |
ICEM meshing problem | Forrest | CFX | 4 | May 25, 2005 18:37 |
ICEM 5.0 - double meshing | Joan | CFX | 0 | November 7, 2004 06:09 |
