flow over extended surfaces in a channel (2D)
i am new to gambit & fluent. i am having problems specifying the boundary types in gambit though i am already done with the geometry and the meshing part. i am trying to get velocity and temperature distribution for :::>
________________adiabatic wall___________ .air |................................................. ...| outlet --->|..................flow.......................... ...|----> ......|................--------->......................| inlet|____E____E_____E_____E_____E_____|_____plate at const temp this is the basic geometry: 'E' is showing the 'extended surface' extended surfaces are RECTANGULAR. plzz tell if i am correct on these parts:- -i have created separate meshes for the channel and the extended surface!!! -applied a ratio of 1.08 in the upward direction(for meshing)!!!!! what should i specify boundary type for extended surfaces(E) , adiabatic wall??? plzzz help... |
