Scripting API Design Modeler - Spline
Hi
Need some help in Ansys Design Modeler scripting API. The goal is to write a script, which draws a spline using control points. According to DM API manual following functions are available : SplineXYW(x,y,weight), SplineKnot(knot), SplineCtrlPtEnd(beginParam, endParam, order, closed, rational, periodic) I wrote some simple script, Code:
p.Sp7 = SplineBegin(); Do you have any experience in writing such scripts ? Any idea of correct syntax to draw a spline based on control points successfully ? Thanks for any help MM |
I have the same problem, did you find a work around?
I gave up modelling the geometry in Ansys Design Modeller and eventually imported geometry from external 3D modelling software (Pro/Engineer).
Ok, thanks
I wil try to give the geometry by points and then let the design modeler interpolate. Something like what is explained here http://www.youtube.com/watch?v=6wQPeBpvwCk |
