Home > Forums > ANSYS Meshing & Geometry
periodic BC
Old   November 29, 2010, 16:08
Default periodic BC
Brian Polly
Brian_P is on a distinguished road
Hello all,
I have a periodic BC in workbench mesher, but fluent does not recognize.
Any suggestions?
Thanks,
Brian
Brian_P is offline   Reply With Quote
Old   December 1, 2010, 14:23
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
In ANSYS Meshing, the boco means that your mesh is generated with periodic nodes...
However, once you get to the solver, you may still need to setup your bocos (inlet, outlet, periodic, symmetry, etc.) It does not happen automatically.
If I have mis-understood the question, please try again...
In the mean time...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   December 1, 2010, 15:31
Brian Polly
Hi Simon,
You have helped me in the past and its greatly appreciated. Originally I tried to mesh this in ICEM but I couldn't get the blocking to workout. So I moved to workbench. From images you can see BC is accepted and mesh generated in WB, but then fluent doenst recongnize and I dont have the option to call Periodic. Also I have matched meshed the periodic faces and inserted a cylindrical coord system.
Thanks,
Brian
Old   December 1, 2010, 18:04
PSYMN's Avatar
Simon Pereira
In fluent, you are just looking at the name of the periodic boundary... What happens if you click edit?
Old   December 3, 2010, 00:53
Brian Polly
When I try to edit that BC I am given no options.
Thanks,
Brian
Old   December 9, 2010, 05:56
Anamurlu is on a distinguished road
You just have to specify that these zones are periodic (in FLUENT):
You write :
mesh
then modify-zones
then make-periodic
enter zones ID, and answer yes to the questions.
Do not forget to specify a cylindrical coordinates system during building your mesh.
Anamurlu is offline   Reply With Quote
Thread Tools
Trackbacks are On
Periodic boundary condition Arif FLUENT 2 January 17, 2014 07:48
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
Activate Periodic Conditions IvanCFD FLUENT 3 May 13, 2010 07:02
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 15:36
