Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Help with sectioning mesh
Old   December 6, 2010, 19:13
Default Help with sectioning mesh
ohjaysus is on a distinguished road
I'm trying to generate a 2D mesh exactly like the one pictured, by joining 4 different geometries together so that the mesh is more detailed in certain regions. The pictured mesh was created using GAMBIT, but I'm limited to using ANSYS workbench to generate the mesh, and we don't have access to ICEM.
I was wondering how to go about this, e.g. should I create each geometry separately and join them with the mesher, or should I join each part together at the geometry stage?
Thanks for your help!
ohjaysus is offline   Reply With Quote
Old   December 11, 2010, 14:02
Default use dm
mrdelaunay is on a distinguished road
for your 2d mesh, use design modeler to create a series of multibody parts for you geometric configuration, then utilize mapped mesh controls and 2d inflation to get the desired mesh
regards,
mrdelaunay
mrdelaunay is offline   Reply With Quote
Old   December 13, 2010, 15:04
thanks for the reply!
I'm still unsure about the process though, DM won't let me connect edges or create joints between my 3D parts. I tried redefining the coordinates of each part so that they would fit in the right places but DM then automatically merges the parts together into single bodies, which I assume is wrong.
Also what is 2D inflation? Is that inflation applied only to the face of a body rather than the whole 3D body? Mapped face meshing works fine except I can't get the smooth circle of inflation out from the circles which are seen in the original picture I attached, I'm only getting very gradual inflation shown in the attachment below no matter what mesh sizing parameters I change.
Apologies for my ignorance, I'm completely new to CFD!
Old   December 13, 2010, 15:07
here's a better image of the type of mesh behaviour I want around the circles...
Old   January 3, 2011, 10:41
Mohankumar.G
Mohankumarg12 is on a distinguished road
Originally Posted by ohjaysus View Post
Hi
u don't have any option in ansys mesher to split or join,u have to do it in DM.
u need to create a enclosed loop to make a surface out of it then u have a option to split it however u want.
after creating a plane surface split it with 2d lines using a command in EXTRUDE-IMPRINT FACES.This command will splits it where ever u want but ensure the 2d lines r not intersecting each other.
Regards,
Mohan.G
Mohankumarg12 is offline   Reply With Quote
Old   January 4, 2011, 10:57
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Ojaysus,
If your parts are automatically joining in DM, you need to add as frozen...
Once in ANSYS Meshing, you can apply inflation by selecting the surface as the body and then selecting the edge for the inflation...
PSYMN is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 40 January 20, 2016 01:08
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 11:40
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
Dynamic Mesh Problem. Tom Clark FLUENT 9 July 7, 2010 07:56
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
