Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] GAmbit problem
Old   December 20, 2010, 13:44
Default Airfoil plotting....
abishai murday
ACER is on a distinguished road
hi everyone
im new on this forum, im actually working on my individual project where im using GAMBIT to create my mesh around a NACA 0015. ive got my coordinates and arranged it as its said in a tutorial , but after importing the airfoil does not come out properly!!!could someone plz help me out, i would really appreciate....
Attachments for my workings
thank you
NNaca0015 ori.dat.txt
ACER is offline   Reply With Quote
Old   December 21, 2010, 03:37
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I don't how it works for defining direct your surface, but as you get not so many points you can afford you to create the naca airfoil manually.
*Import the vertex data
*create all edges defining the airfoil by linking points (couple of points)
*if all the points disturb you, you can merge all the edges into one.
*finally creat a surface (wireframe) by choosing the upper and lower edges
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 25 September 11, 2011 07:58
Gambit installation problem Panos FLUENT 4 March 5, 2009 22:44
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
