Home > Forums > ANSYS Meshing & Geometry
[ICEM] Problem with the Split Face Option
Old   December 28, 2010, 07:46
Default Problem with the Split Face Option
saisanthoshm88 is on a distinguished road
I have a problem while working with the Split Face option in ICEM CFD and the attached document describes my problem with illustrative images
Please suggest ways of overcoming the problem.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   December 29, 2010, 23:23
Default Index control is not keeping up.
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Hello, the problem is just the index display not keeping up with your face splits... I just put in a bug report on your behalf.
But in the mean time, the work around is simple.
Just right click on the blocking branch of the tree and select index control. (or if you are on the blocking tab, just move the mouse cursor into the screen and hit the "i" hotkey on your keyboard.) This will bring up the index control in the lower right corner.
The index control is very useful for ICEM CFD Hexa. It lets you control how much blocking is active. This is good for reducing screen clutter, but it is critical for limiting how far various operations like split or redistribute Ogrid edges can go. Hexa Experts use this all the time... In your case, if you split a face once, all is fine (behind the scenes the index control is one off, but only the Vorfn region is affected so you don't notice). However, if you split that face a second time, the index control is now two splits behind and part of your blocking appears to vanish.
The workaround is to hit the "Reset" button in the Index Control window.
PSYMN is offline   Reply With Quote
Old   December 29, 2010, 23:26
Default Block splits?
PSYMN's Avatar
Simon Pereira
One more quick thought... I hardly ever use face splits (which is probably why this bug you found was not fixed sooner). Are you sure you need to use it?
Most often, a block split is more robust than a face split because it exposes all the "implied splits". If you do face splits on this side, and then later do face splits on another parallel face, you may have issues as it tries to connect all the hidden implied splits. Things may not go the way you expect and the mesh will follow. Most experts find that it is just more straight forward to use block splits...
Old   January 12, 2011, 18:05
Default Fixed
PSYMN's Avatar
Simon Pereira
This was entered into our defect database and has been fixed for all known areas of the code... Thanks to Sai for making us aware of the defect and to Jari for fixing it).
The fix is in v14.0 Preview 2 or later.
In the mean time, the work around is just to reset the index control.
Thread Tools
Trackbacks are On
Error message: Insufficient Catalogue Size Paresh Jain CFX 31 June 7, 2016 21:31
Import netgen mesh to OpenFOAM hsieh Open Source Meshers: Gmsh, Netgen, CGNS, ... 32 September 13, 2011 05:50
Transient simulation Pramila Main CFD Forum 2 October 1, 2010 04:01
Import problem ARC Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 February 27, 2010 11:56
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
