ANSYS Workbench ,geometry problem
Old   January 9, 2011, 05:09
Default ANSYS Workbench ,geometry problem
smn
smn is on a distinguished road
hi:
i want to simulate a shell sphere and find stress and strain through it. a "pressure" of 20mmHg is applied to the inner surface of sphere and "fixed support" must be applied to the center point of sphere to prevent its moving.
my difficulty is about assigning the center point in the geometry modeling.(inside of shell where there is no material)
can anyone help me?
thanks in advance.
Best Regards,
smn is offline   Reply With Quote
Old   January 10, 2011, 14:15
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I don't have the exact answer you were looking for (maybe someone else will), but I can suggest that you cut the model in half (or even smaller slices). If you apply symmetry or periodic boundary conditions, the result should be the same, but it will solve faster and you will have geometry running thru the center point that you can fix...
PSYMN is offline   Reply With Quote
Problem importing the images to ansys workbench kmgraju CFX 12 November 2, 2010 21:11
ANSYS Workbench on Linux CPUcruncher ANSYS 4 July 11, 2010 09:19
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
problem in import ANSYS mesh sheryl CFX 2 April 30, 2005 21:30
problem in reading ansys file satya bulusu Siemens 3 November 27, 2002 03:29
