Home > Forums > ANSYS Meshing & Geometry
Gambit
Old   January 9, 2011, 13:52
Default Gambit
Touré
Touré is on a distinguished road
I want to select one line but all the lines of of the drawing are selected when I click on the drawing. I don't know why ?
Touré is offline   Reply With Quote
Old   January 10, 2011, 02:56
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you import your geometry?
a picture may hel to understand your issue
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 10, 2011, 13:13
Touré
I did not import any geometry. It happens when I want to mesh the edges one by one. It picks all the edges at the same time instead of one.
Old   January 11, 2011, 01:46
-mAx-'s Avatar
Maxime Perelli
If you go to Geometry/Summarize edges, are you able to pick just one edge, or gambit selects again all the edges?
In other words, did you merge all the edges?
Thread Tools
Trackbacks are On
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 15:05
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Does Gambit has a maximum allowable grid number? spartan1516 ANSYS Meshing & Geometry 7 March 25, 2010 10:08
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
